Just completed my first build with:
i3 10100  10th gen
Gigabyte Z590 Aorus Ultra (Lga 1200)
WD 1 TB Wd Blue Nvme drive
32 Gigs 3200MHz Vengeance ram
Everything in Bios is ok. Activated Xmp
Win usb install boots and runs perfectly
Ran Win 11 Pro usb setup and got the message: "System does not meet requirements"
Components are more than adequate for Win 11 Pro install.
I can install Win 10 via usb (this works!) and then change registry entries to update to win 11, but would rather direct install of Win 11.
What gives? Do I need to change some Bios settings so the Win 11 install usb recognizes the validity of my components?
https://linustechtips.com/topic/1482345-new-build-help/
Is your CSM set correctly?
Xmp isn't always a good thing, try setting that back to default and see if it accepts the setting.
Are you using gpt with the ssd?
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1482345-new-build-help/#findComment-15757673
I am using NTFS + GPT with the WD 1 TB Nvme drive. I assume that's the right choice.
Not sure what the CSM settings should be set at. Any suggestions?
This is my first build with help from the "Linus - How to Build your Pc"
All connections and everything hardware related seems ok. Bios boots.
Many thanks for your help SansVarnic
Much appreciated
https://linustechtips.com/topic/1482345-new-build-help/#findComment-15758474
