Upgrade hardware. need help
Go to solution Solved by Hidden Orange,
If it still works, Fry's has the i5-4430 for $99.99 that you can price match at Staples. Here's the link to the thread on LTT: i5 4430 on sale. So, you could make a i5-4430 and GTX 760 build.
first one, but I would rather get a amd chip than that i3.
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
i got 2 option here for gaming system and i need your advice which is good
Processor i3 4130 3.4Ghz (2 cores)
Mobo ASUS B85M-G
GPU Gainward GTX 760
or
Processor i5 4440 3.3Ghz (4 cores)
Mobo Asrock B85 killer
GPU Gainward GTX 750 ti
i3 with 760 will be better! :)
| CPU: An abacus | Motherboard: Tin foil | RAM: 2 Popsicle sticks | GPU: Virtual Boy | Case: Cardboard box | Storage: Cardboard | PSU: 3... Er... Make that 2 hamsters | Display(s): Broken glass | Cooling: Brawndo | Keyboard: More cardboard | Mouse: Jerry | Sound: 2 Cans of SpaghettiO's |
