Budget (including currency): €1,5K, although €2K is also find, just don't think its necessary.
Country: Netherlands
Games, programs or workloads that it will be used for: AAA games, honestly just that lol
Other details Ive got some part list already put together but im just not sure about them. Goal is to play on 1440p 144hz. Existing lists: https://nl.pcpartpicker.com/list/cr2CQ6 (12600k 4070ti), https://nl.pcpartpicker.com/list/Ch2MH2 (5600x 6800xt) more expensive ddr5 list: https://nl.pcpartpicker.com/list/3GLqfv (7700x 6800xt)
| Ryzen 7 5800X3D | CM ML240L V2 | B550 Aorus Elite V2 |
| 2x16GB Corsair 3600MHz CL16 | XFX RX 6950 XT MERC | NZXT C850 Gold |
| 1TB SN770 PCI4 SSD | 512GB Patriot Memory P300 | Corsair 4000D |
https://linustechtips.com/topic/1481794-need-help-with-pc-parts/
Honestly, you're already there. These are all well configured and you're getting some of the best performance for your money. You could save a few euros here and there if you want to really min max (ie foregoing the 100eur aio for a cheaper model or beefy air cooler) but at this point it is personal preference I think.
Good Luck!
EDIT: If you want alot of AAA games installed I'd get a second game drive on top of the TB you configed
Edited by Saygi
More info
Good Luck!
Yea the AIO looks nicer imo for the intel one, and I already have a 500gb SSD with windows and 1tb HDD from my old pc. Thanks a lot for replying, happy to see I still know a bit about configuring pc's 😄
Good Luck!
But, if yo ucan, which list do you think is best for me? 1440p at 144h high/ultra is what I want to play on most games, but I don't wanna go overkill
I would go with this list:
It is the cheapest, but also seems to be less overkill.
Main "Rig"=HP 11A G6 EE
Android Tablet
Raspberry PI Zero W 2
If you have any fun ideas for things for me to do with my PI, send me a direct message.
I plan to upgrade within a few months to a proper computer.
