Hi,
Sorry if this is in the wrong subforum, wasnt sure where to post it.
I was wondering what the power draw was in Watts of the corsair lighting node pro with the led strips installed?
I cant seem to find any info on it even after downloading the manual.
I dont have much headroom so thought it would be best to ask
Thanks
https://linustechtips.com/topic/1481683-corsair-lighting-node-pro/
What headroom are you referring to exactly?
I believe its powered via motherboard's USB header? That's like few watts at best.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
Just the overall system power draw, I have a 3090ti and an overclocked i7 12700kf, the psu is an msi 850w gold. When I ordered my pc it was with a 3080ti but they upgraded me.
So im just worried that the lighting node pro would tip it over the edge, it uses usb on motherboard and also goes into a sata port.
If its only 5 watts then should be good but wanted to make sure it wasnt 40 watts or something like that
