compare games with same resolution and graphics settings not UserBenchmark which isn't always accurate
current PC:
PC configs I used before:
Just now, Gilgamang said:
Yea but I consistently got really low scores and his were much higher. That doesn't mean anything?
What specs do you have, what specs does your brother have?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
You can see in the benchmark. He's running a i9 10850k on a Z490 mobo and I'm running a i7 12700k on a Z690. Is it possible that the psu could be the issue and somehow my power delivery isn't working right? Or maybe something in the Nvidia control panel? I would think power would be the issue since my parts are better besides the ram.
I also just got a 4070ti which is also underperforming quite a bit. That's why I suspected the issue and tried my 3080ti in another pc.
Do you know what your PSU is and what your brother's is? Also does your case maybe not have a good way to deal with component heat? I'm not particularly experienced with computer hardware but that would be my first guess.
His is an Apeva 800watt and mine is a corsair rmx 850 watt which is a much better cpu. Unless it is faulty in some way. My temps are good too so I don't think that's the issue.
Your GPU score seems OK but your CPU score seems to be low when comparing with equal systems (GPU and CPU).
Can you make a screenshot of the hwinfo summary dialog.
Does your memory perform well?
Have you checked your CPU temps and CPU speed while running performance test?
I use furmark's CPU burner for quick testing CPU and GPU temp's on load and if the CPU is throttling caused by high temp.
On my system where I upgraded the CPU yesterday the AIO I used from the old system can not keep the CPU cool enough that it can run at full turbo speed (4800Mhz) instead it reaches immediately 90°C and throttles the CPU speed to 4550 MHz. I have already order a bigger AIO cooler and hopefully the CPU can then perform in full turbo speed.
This is my CPU - Z result. Does this look okay?
Intel Core i7 12700K @ 4688.53 MHz - CPU-Z VALIDATOR (x86.fr)
The screenshot is what HWinfo64 looks like during the CPU stress test
That does not look to bad. It looks good.
When comparing your values with the official Intel spec for the 12700K it is good.
CPU-Z shows P-Cores freq. 4688 Mhz of possible 4900 Mhz
and for E-Cores 3591 Mhz of possible 3800 Mhz
But there is some room for more. Temps are good so why not getting full turbo speed?
Your CPU supports "Intel® Turbo Boost Max Technology 3.0 Frequency". Maybe you can check in BIOS if this is enabled (OC Tweaker - CPU Configuration).
Be sure you know how to reset CMOS when playing around with overclocking settings so you can go back to a stable state. "Intel Turbo Boost Technology" and "Intel® Turbo Boost Max Technology 3.0 Frequency" should be safe to change.
There should also be settings for thermal thermal velocity boost (below 70°C). Check following article https://www.intel.com/content/www/us/en/gaming/resources/how-intel-technologies-boost-cpu-performance.html for a description.
