Help needed with diagnosing a problem !
Solved by SkilledRebuilds,
I'd keep trying to find a way to boot with SINGLE/Individual sticks of Ram as a starting point...
Go back to Basics,.. Mobo/CPU/1 stick of Ram/GPU//PSU/Keyboard without anything else connected.
One by one RAM stick, in each slot, will it boot with one of these configs..
Then if it boots,... take it from there.
Assuming something IS bad when troubleshooting is a bad idea,.......iE "Old AMD GPU" because now you don't even consider RAM to be the culprit and may miss something if you lay it all on the "Old AMD GPU" Then you might spend money on a replacement GPU to find its one of the RAM sticks all along.
1 stick at a time, each slot would be where I start.
