it would depend on if the parts need to be cooled or not. if the machine is just going to be idling in a cool room then probably not but if you're loading the hardware a lot in a hot room then yeah fans would be good.
you don;t determine fan choice by rpm , instead look more at cfm , and you can buy as many as you need until all the available spots on the case are occupied.
https://linustechtips.com/topic/1479464-case-fans/#findComment-15738455
2 hours ago, Someone69 said:
Im gonna buy a h510 flow case, a be quit cpu cooler pure rock 2 black, a triple fan rx 6700XT 12gb, do i need case fans with that, and what rpm/howmany fans.
be quiet can be a bit over priced and opposing the name a tad bit loud, i would recomend geting a noctua cromax cooler instead. also no mater what you will probably need at least 3 fans (i would go with the noctua pwm 120mm fans aka the grey ones)
"its all about the pentiums baby"
- "Weird" Al Yankovic's its all about the pentiums
https://linustechtips.com/topic/1479464-case-fans/#findComment-15738635
But the noctua cromax cooler is like double the price of bequit pure rock 2 black
https://linustechtips.com/topic/1479464-case-fans/#findComment-15739144
