Budget (including currency): $2000 USD
Country: United States
Games, programs or workloads that it will be used for: 1440p high/ultra settings- Fortnite, Fall guys, Warframe, Destiny 2, Forza Horizon 5. VR games max settings- Beat saber, Echo VR Arena/combat, Bonelabs, Boneworks. Other workloads- school work, Light Blender and video editing.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):  I already bought a corsair 4000D airflow (don't include that in the budget:) I want it to have an ryzen 7000 gpu or Nvidia 4000 gpu. I want an intel raptor lake cpu or ryzen 7000 cpu. 32 gb Ram. 1Tb ssd. I also want the keyboard and mouse in this budget (something that's silent, satisfying, swift) I have a LG ultra gear 1440p 32 inch 165hz. Thanks for the help!
https://linustechtips.com/topic/1479241-help-with-2000-pc-build/
https://pcpartpicker.com/list/M8YGgb
CPU: Intel Core i5-13600K 3.5 GHz 14-Core Processor ($319.97 @ Amazon)
CPU Cooler: Noctua NH-U12S chromax.black 55 CFM CPU Cooler ($79.95 @ Amazon)
Motherboard: Asus TUF GAMING Z690-PLUS WIFI D4 ATX LGA1700 Motherboard ($219.00 @ Amazon)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory ($49.99 @ Amazon)
Storage: TEAMGROUP MS30 1 TB M.2-2280 SATA Solid State Drive ($49.49 @ Amazon)
Storage: Patriot P210 1 TB 2.5" Solid State Drive ($42.99 @ Amazon)
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB LHR 10 GB Video Card ($897.99 @ EVGA)
Case: Fractal Design North ATX Mid Tower Case ($105.00)
Power Supply: Apex AG-M 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($99.99 @ Amazon)
Keyboard: Mad Catz The Authentic S.T.R.I.K.E. 4 Wired Gaming Keyboard ($99.98 @ Amazon)
Headphones: Mad Catz F.R.E.Q. 5 5.1 Channel Headset ($79.98 @ Amazon)
Total: $2094.32
Generated by PCPartPicker 2023-01-06 08:31 EST-0500
"its all about the pentiums baby"
- "Weird" Al Yankovic's its all about the pentiums
Total: $2094.32
Why not 2 x 16 gigs tough? And maybe the cooler can be a littlebit cheaper since its only a 13600k. Also try to swap the 3080 for a 6950. Its not that more expensive and some are less expensive but they have great preformance like the 3090ti.
PCPartPicker Part List
CPU: Intel Core i5-13600KF 3.5 GHz 14-Core Processor  ($308.70 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 White 66.17 CFM CPU Cooler  ($46.36 @ Amazon)
Motherboard: MSI PRO Z690-A DDR4 ATX LGA1700 Motherboard  ($199.99 @ Amazon)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($58.99 @ Newegg)
Storage: Crucial P3 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($79.98 @ Amazon)
Video Card: PNY XLR8 Gaming VERTO EPIC-X RGB GeForce RTX 4080 16 GB Video Card  ($1199.99 @ GameStop)
Power Supply: EVGA SuperNOVA 850 GT 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($129.99 @ Best Buy)
Total: $2024.00
Generated by PCPartPicker 2023-01-06 11:32 EST-0500
To be an expert is to know more about less.
  • 2014 Build --> FX 8350 4.7GHz {} ASRock Fatal1ty 990FX Killer {} Reference GTX 980 4GB {} 2x4GB 1866MHz HyperX {} Seagate 2TB 7200rpm {} 840 EVO 120GB {} XFX PRO850W {} Noctua NH D14 {} Fractal Define R4 White Windowed
  • 2018 Build --> Ryzen 7 2700X {} ASRock Fatal1ty X470 Gaming K4 {} Gigabyte RTX 2070 8GB {} 2x8GB HX Fury 3200MHz {} Toshiba P300 2TB {} Kingston 480GB A1000 {} Corsair RM750W {} Enermax LIQMAX II 240 {} Fractal Focus G
  • 2021 Build --> Ryzen 9 5900X {} ASUS ROG Strix X570-F GAMING {} ASUS GeForce RTX 3080Ti ROG STRIX OC {} Gigabyte AORUS RGB DDR4 32GB {} Kingston KC2500 M.2 2280 NVMe 2TB {} Seasonic FOCUS GX-1000 {} ASUS ROG Ryujin 240 AIO {} NYXT H710i
  • 2026 Build --> Ryzen 9 9950X3D {} ASUS ROG CROSSHAIR X870E HERO {} ASUS GeForce RTX 5090 32GB ASTRAL LC {} G.Skill TridentZ Royal Neo RGB Silver DDR5 CL28 6000MHz 2x16GB {} Samsung SSD 4TB 9100 PRO M.2 {} Seasonic 1600W PRIME TX Noctua Edition {} Fractal Lumen S36 V2 RGB 360mm AIO {} Fractal Design North XL Charcoal
Total: $2024.00
Why only 16 gig of memory tough
When on budget. I usally go for less RAM to get the best other parts in the budget. RAM can always be upgraded later on.
Total: $2024.00
Does that MOBO have bios flashback?
Dont knoz that info but maybe you could ask the shop to see if it has proper bios and if not to flash it.
