HELP!!! MY PC IS UNDERPREFORMING!!!
Solved by Zando_,
2 minutes ago, NoahPCBUILDER said:Also I am thinking of upgrading my cpu, will this help?
Yes. AFAIK Rust is CPU bound (mostly single core) and the R7 2700 is pretty measly on single core performance. Tis why there was little improvement from upgrading the GPU. A 5000 series chip should be a drop-in upgrade with a simple BIOS update (check the supported CPUs list for your motherboard to confirm). I'd shoot for a 5600X or higher for a good improvement over the 2700.
