Hi yall, I've just started using a new Xbox controller with my PC which has been a Treat plugging into my 4k tv replaying favorites via controller but due to my own ignorance about anything xbox I didn't realize the controller takes regular batteries...my first thought was what F@in year is this? but after I calmed down and thought about how nice it must be to be able to quick swap battery packs (glaring at useless ps4 controller that wont charge) I found there are sold separate rechargeable options so I'm here to get some suggestion/recommendations
                          Ryzen 5800X3D(Because who doesn't like a phat stack of cache?) GPU - 7700Xt
                                                           X470 Strix f gaming, 32GB Corsair vengeance, WD Blue 500GB NVME-WD Blue2TB HDD, 700watts EVGA Br
 ~Extra L3 cache is exciting, every time you load up a new game or program you never know what your going to get, will it perform like a 5700x or are we beating the 14900k today? 😅~
https://linustechtips.com/topic/1478545-battery-packs/
Whichever rechargeable battery pack that is compatible with the controller you have, has good reviews, and is within your price range to purchase. Follow those steps and you can't really go wrong. As for which pack to recommend specifically? No idea. I've always just bought rechargeable Xbox controllers.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1478545-battery-packs/#findComment-15732315
Thanks
Yea I've never been in the Xbox scene so I didn't know 😅 I just happened to have it in my mind I wanted a controller for my PC and happened to see $30 Xbox controller,seemed like a good price considering it's almost $80 for PlayStation or joycons
https://linustechtips.com/topic/1478545-battery-packs/#findComment-15732326
I’ve heard good things about LIFEPOD batteries.  Nitecore is often a reliable brand.  They were developed for night diving equipment.  Having some rechargable letter batteries (aaa, aa, c,d) can be handy.  I use 18650s mostly, but they’re always rechargable, and I don’t know that they would fit in a controller anyway.
In which I ramble about chargers
For any type of rechargable battery you will want a charger.  Sometimes the charger  is included in the battery pack or the device. Some chargers will charge more than one type of battery (mine will do most things but not LiFEPODS for example.  I’ve got an xtar dragon 50 iirc)
in which I ramble about how batteries work
There are a bajillion chemistries.  The danger with rechargable batteries is for a while (and maybe still) the things were listed as 1.3v instead of 1.5v.  They didn’t work in some things and for others they didn’t work for long.  Batteries are a bit like balloons. They start at a high wattage and drop slowly until they are no longer able to power the thing in question and the number is the average.  3.7w lithium batteries (there are a bunch of chemistries) are 4.1-2.5 generally.  Different devices will cut out at different wattages. Generally higher than 2.5.  I’ve seen 3v, I’ve seen lower.  What this means is if the average wattage is lower than the standard listed average you may need to find out what their actual charged and discharged voltage is and what the working range of your device is.
Edited by Bombastinator
https://linustechtips.com/topic/1478545-battery-packs/#findComment-15732365
