Budget (including currency): 2500euro
Country: Greece
Games, programs or workloads that it will be used for: Black desert online, Path of Exile, Streaming
Other details idk if i should go for  amd or intel. id like the best value for my money i know prices are in the sky rn but that aint much of a problem. ill start on the build in about a month or so id love diff ideas.
Note secondary storage drive is not needed ill use my old 1tb one.
https://linustechtips.com/topic/1478464-please-help-me-build-a-pc-first-timer/
12 hours ago, emosun said:
Wait until you are going to build the machine as prices change month to month so no sense in making a parts list
i only wanted to get an idea of what i could be looking for but yeah for sure prices go up and down and i heard cpus might go less on february notnqute sure though
https://pcpartpicker.com/list/MnCWv3
i tried and came up with this i know os 200 more than the price on my  budget. if you have some other recomendations that would reduce price but give me same performance. im not even sure about gpu and cpu cooler also the cpu idk if this one is the best oick out of the hundreda that are out there.
A few things. The ram is very expensive(prob more speed than you need. I also recomend going with non rgb vengeance)
Dont go with an 3080. It isnt that relevant anymore. For the same price you can get an 7900xtx which is way better
Also dont include an os. You can get keys for much less money
The 4000d is a very good case for airflow. But you need at lesst 3 front intske 120mm fans for it
i changed to a 750w power supply to reduce costs and i got a non rgb vengeance as mentioned. im kinda thinking of going for the 4080 instead of 7900xtx but im not quite sure if its worth it.
