BSOD, Need help
Go to solution Solved by Jobbe03,
Install your MB drivers
After just getting my Desktop Pc back from a repair, it was working fine for a few days, i was sitting in the living room, since my room was occupied, when the days passed, there was space in my room, so i moved my pc in there. it was working. for an hour, and suddenly i got a BSOD, and then it happened again with about an hour between, it happend 3 times before i began to write this. i searched the internet for a solution, but i couldnt really figure it out. but i have some data from the BSOD that probaly are usefull to help find a solution.
This is what i get, notice on the second photo, the technical information is different. This is only 2 out of the 6 BSOD i had this evening.
It also seem to before the BSOD happen, the computer lags, and sound also lags. but sometimes it might lag the same way, without a BSOD happening
Edited by taomaokakao
https://linustechtips.com/topic/147680-bsod-need-help/
https://linustechtips.com/topic/147680-bsod-need-help/#findComment-1972663
The guys who repaired my pc, changed the MoBo, and it wouldnt make sense that they wont install drivers aswell. But i installed the drivers again to be sure
doesnt seem to help
Take it back to the guy and nicely explain the problem to him.  Politely ask for him to fix it without charging you extra because he didn't fix it properly the first time.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/147680-bsod-need-help/#findComment-1974803
