Cooler Master PSU!
Go to solution Solved by --SID--,
The MWE 450w Bronze is a bit more efficient, a bit higher quality and has a better full range input. Overall it's the better unit that's more worth than an extra 50w.
Guys what is the difference betwen these 2 PSU?
Cooler Master MWE 500 WHITE 230V - V2
Cooler Master MWE Bronze 450W V2
The Cooler Master MWE 500 WHITE 230V - V2 Is Cheaper But Has More Watt,And The Cooler Master MWE Bronze 450W V2 Is More Expensive But Has Less Watt?
So Witch Should I Choose For My Build With
AMD A320M-K
R5-5500?
https://linustechtips.com/topic/1476740-cooler-master-psu/
