CPU compatible with MOBO
Solved by SpookyCitrus,
You'll need to check with the seller to see if the board is up to date, B660 is previous Gen so it will need a bios update to work with 13th Gen. Freshly manufactured new stock should have the bios update from the factory but even if it's just a month or two old it most likely won't. I'd check with the seller before purchase or get a 13th Gen specific motherboard.
