Hey guys, so with my new rig, I sort of forgot to buy a keyboard. (booing in background) so I'm saving up for a K70. I am using a Mac keyboard currently, and after searching the web, I could not find anywhere how to take screenshots on a Mac keyboard as a shortcut, not the snipping tool. Please tell me if there is a way to take screenshots with a mac keyboard, or if there's a way to set one of my programmable keys on my mouse to be a screenshot key, or if it just isn't possible. I have a Corsair M40 mouse, if it's important.
FANBOY OF: PowerColor, be quiet!, Transcend, G.Skill, Phanteks
FORMERLY FANBOY OF: A-Data, Corsair, Nvidia
DEVELOPING FANBOY OF: AMD (GPUS), Intel (CPUs), ASRock
https://linustechtips.com/topic/147648-taking-screenshots-help/
Does your keyboard have PrtScrn?(or SysRq)
Press it.That will save what is being displayed on your monitor to the clipboard.
Then open an image editor(like paint) and paste.
https://linustechtips.com/topic/147648-taking-screenshots-help/#findComment-1972260
fn + Shift + F11 was what I found after a quick google.
That work?
Nope
nope
BTW, I have Fn keys up to 19 on this keyboard.
https://linustechtips.com/topic/147648-taking-screenshots-help/#findComment-1972287
http://www.take-a-screenshot.org/
Click on the mac section and try that.
command + shift + 3(not numpad)
https://linustechtips.com/topic/147648-taking-screenshots-help/#findComment-1972301
Nope
https://linustechtips.com/topic/147648-taking-screenshots-help/#findComment-1972372
Download Gyazo. https://gyazo.com
The problem is, I want to be able to take screenshots in full-screen applications. I don't think I can do that with Gyazo. Can I?
https://linustechtips.com/topic/147648-taking-screenshots-help/#findComment-1972544
