Guys my computer won't start and I made the mistake of plugging and installing everything first. Here is my question, I installed the 24 pin connector and the 12v power at the top of the motherboard. I made sure I connected all the power and led pins correctly installed my gpu correctly what could be the problem any suggestions?
Here's some pictures: http://imgur.com/0VK...EJ2bW8J,2DestCi ---------This shows the 12v cable plugged in at top of the motherboard.
http://imgur.com/0VK...2bW8J,2DestCi#1---------This shows the 24 pin connector in.
http://imgur.com/0VK...2bW8J,2DestCi#2--------I have a corsair fan plugged into the CPU fan so the motherboard will turn on..Also I have tried this with my cooler on and everything it didn't work.
http://imgur.com/0VK...2bW8J,2DestCi#3-----This image shows where I plugged in stuff on my PSU to the left is my CPU power cable next to that is the 24 pin Cable plugged in.
Specs: http://pcpartpicker.com/p/3CTPE---------The specs to my computer.
Nothing turns on no fans no nothing what could be the problem?
https://linustechtips.com/topic/147612-my-fail-help/
if nothing starts its the PSU.
Okay.
Is tho power switch turned on from the back?
Yes it is.
did you plugged your cpu cooler
I had it plugged in at first everything in and then it didn't start. So, I unmounted it and just hooked a fan up to the CPU fan slot for now to test this chip doesn't come with a stock cooler
CPU cooler?
Try a different psu?
Ram?
Or shorted mobo!
Thing
It might be the PSU or RAM idk yet.
https://linustechtips.com/topic/147612-my-fail-help/#findComment-1971759
Okay.
Yes it is.
See if you can get hold of another psu and try, if that does not work then use one of the sticks of ram!
Thing
https://linustechtips.com/topic/147612-my-fail-help/#findComment-1971772
How do I do that?
The green and any black connector. Make sure to unplug the 8pin and gpu, before doing this.
Intel 4790k | Asus Z97 Maximus VII Impact | Corsair Vengeance Pro Series 16 GB 1866Mhz | Asus Strix GTX 980 | CoolerMaster G550 |Samsung Evo 250GB | Synology DS215j (NAS) | Logitech G502 |
https://linustechtips.com/topic/147612-my-fail-help/#findComment-1971799
