High CPU temps Ryzen 5600x
Solved by zipspence,
So unfortunately with AIO coolers they are prone to failure and DO eventually become inoperable after long use. The fans and pump might be running perfectly fine, but that doesnt mean the close loop system didn't evaporate out. Realistically there should always be 1 pipe hotter than the other as it takes the liquid away from the CPU to the radiator.
My suggestion in this case would be to get another AIO, but for me personally I have gotten away from AIO coolers and back to Towers purely because the performance from a tower cooler is better and less prone to failure. So it sounds like your AIO is shot.
