No power?
Go to solution Solved by aDoomGuy,
9 hours ago, Switch pro said:
Nothing no LED or anything
Judging by your answer it is safe to assume you managed to remove the battery? Voltage coming out of the charger so it is either something internal inside the laptop or the charging port may be bad, methinks.
5 minutes ago, Switch pro said:
Have an Old Dell Inspiron 3493 just dug up and there's no power even after I plug in power supply and power button doesn't work no LED on computer
Maybe there's a physical switch on the power supply?
Are all power connectors secured on the motherboard?
https://linustechtips.com/topic/1474885-no-power/#findComment-15708021
Were you using it and it stopped working?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1474885-no-power/#findComment-15708052
https://linustechtips.com/topic/1474885-no-power/#findComment-15708791
Well the charge port is connected to the laptop
And the power button is aswell
https://linustechtips.com/topic/1474885-no-power/#findComment-15709641
