help i can't get dts!!
Go to solution Solved by Sharif,
update i fixed it by reinstalling k lite codec pack and choosing 5.1 when installing
i have the logitech z506 (recently bought)
when i played a music/sample file which is 6 channels it runs fine
but all the video 6 channels files only work in stereo
those video clips on you tube works fine in 5.1
i downloaded some sample which are 5.1 but they also play in stereo
please help
When i run the tests in the driver they perfectly work fine
update  found out its a problem with mpc but how do i fix it
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/147487-help-i-cant-get-dts/
ExSystems
https://linustechtips.com/topic/147487-help-i-cant-get-dts/#findComment-1970180
