Posted December 15, 2022 can someone explain what's going on please? why so high temps on cpu package at low load (5%) and water temp only 30C ?? 3 rad fans pushing air from outside in (rad receiving the hottest water) and 6 rad fans pushing from inside out 1 additional intake fan at the rear. Pump running full speed and fans too (forced manually) The only real active process is steam downloading and verifying a game. Thanks Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 15, 2022 Bad mount, no tim, no water or severe lack of water flow. Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz Spare RIg Lian Li O11 AIR MINI, I7 4790K, Asus Maximus VI Extreme, G.Skill Ares 2400 32Gb, EVGA 1080ti, 1080sc 1070sc & 1060 SSC, EVGA 850GA, Acer KG251Q 1920x1080@240hz Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 15, 2022 What are load temps like under Cinebench R23 all-core after 10-15 minutes (it defaults to a 15 minute loop)? Intel HEDT and Server platform enthusiasts: Intel HEDT Xeon/i7 Megathread Main PC CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads Motherboard: EVGA X299 Dark RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16 GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block Storage: 1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo Optical Drives: LG WH14NS40 PSU: EVGA 1600W T2 Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM OS: Windows 11 Display: LG 27UK650-W (4K 60Hz IPS panel) Mouse: EVGA X17 Keyboard: Corsair K55 RGB Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3 Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 15, 2022 13 minutes ago, FUSER said: can someone explain what's going on please? why so high temps on cpu package at low load (5%) and water temp only 30C ?? 3 rad fans pushing air from outside in (rad receiving the hottest water) and 6 rad fans pushing from inside out 1 additional intake fan at the rear. Pump running full speed and fans too (forced manually) The only real active process is steam downloading and verifying a game. Thanks Its a Very hot chip. Not sure what you expected any differently? 77C Under a fullload is amazing for a 13900k if you did not do any tuning. What were you expecting exactly? Its 250W on a chip that size, that much watercooling is designed for silence and performance, but you are asking a lot of it. It has to go through a IHS, that alone can take quite a bit of the temps, along with the proper design of the cooling plate, optimizing exactly where the 13900k die is and everything, its quite complicated. Overall, its doing its job just fine, your expectations are all out of wack. You want cooler thermals? Optimize the voltage curves and power, the frequency and then you will see a drastic thermal drop. The chip is doing its best to hit 5.8 ghz, or if its an allcore workload, usually whichever boost bin it sees fit with the thermals. My Gaming and Editing Rig : http://linustechtips.com/main/topic/500716-red-gaming-build/ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 15, 2022 Author 35 minutes ago, Zando_ said: What are load temps like under Cinebench R23 all-core after 10-15 minutes (it defaults to a 15 minute loop)? It has been overclocked with 6.1Ghz on 1 P-Core and rest p-cores around 5.6-5.8 Ghz. Couldn't achieve anything more stable using ASUS AI overclocking. definitely thermal throttling as most P-Cores drop below 5.5 Ghz. Perhaps lowering voltage would fix this issue to an extent (any guide for Z790 mobo + i9-13900K for manual overclocking by any chance?) Of note since i run 4 sticks of DDR5, I can only get 4800MT/s instead of 5200MT/s - not sure if this matters on the Cinebench score as much. After cinebench testing looks like my watercooling system has quite of capacity and defies any issue with insufficient contact with the CPU. Final Cinebench R23 score (15 minutes): 36,063 (multicore) These are 7 minutes in Cinebench R23: Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 15, 2022 2 hours ago, FUSER said: Couldn't achieve anything more stable using ASUS AI overclocking. definitely thermal throttling as most P-Cores drop below 5.5 Ghz. Perhaps lowering voltage would fix this issue to an extent (any guide for Z790 mobo + i9-13900K for manual overclocking by any chance?) I haven't dug into the latest gen stuff as I don't own any of it, buuut I can tell you that ASUS AI Overclock loves dumping ungodly voltage into your chip in an attempt to make it stable, I would recommend disabling it and manually tuning. What voltages is it pushing vs stock, and if you revert to stock what do your temps look like? Also, can you expand the "Core Temperatures" dropdown in HWiNFO64, that will let you see per-core temps. IIRC the mounting solution for 12th/13th gen flexes them enough to cause uneven contact (thus the aftermarket contact frames to apply even pressure). If you're seeing large differences between individual core temps when they're all under the same load and at the same boost clock/voltage, that could be a sign of it. Intel HEDT and Server platform enthusiasts: Intel HEDT Xeon/i7 Megathread Main PC CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads Motherboard: EVGA X299 Dark RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16 GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block Storage: 1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo Optical Drives: LG WH14NS40 PSU: EVGA 1600W T2 Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM OS: Windows 11 Display: LG 27UK650-W (4K 60Hz IPS panel) Mouse: EVGA X17 Keyboard: Corsair K55 RGB Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3 Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
