Hi, I need somebodys help. My dad built a computer for 3d modeling and cad.
Computer specs:
CPU: I7 10700f
motherboard: Asus prime H410m-e
ram: Vgen 2x32GB 2666Mhz
GPU: Nvidia Quadro RTX  4000
Storage: Vgen 1tb nvme m.2 ssd and a ironwolf 1tb hdd
Right now, when opening large files such as sketchup and Autodesk Autocad, the pc will suddenly crash or will restart by itself. Right now i think that the motherboard is causing this issue as when i take one stick or ram out, the pc will run stable on any slot. And I also had thought of the psu being the issue as it cannot handle the power usage of the pc when being used. But I do not know which one to cause the problem, because I had tried other ram sticks such as the corsair vengence lpx 2x32GB 2666Mhz and it will still run like so. I also tried changing the gpu for a GTX 1050ti and it still did not work. Anyone knows why?
https://linustechtips.com/topic/1473941-pc-running-unstable/
Computer specs:
CPU: I7 10700f
I would try updating your BIOS at this point, if that doesn't work its probably the motherboard. You have done a pretty good job narrowing everything else down. Since the Quadro 4000 RTX only has a max power draw of 170, it should be enough.
Have you tried restarting it?
https://linustechtips.com/topic/1473941-pc-running-unstable/#findComment-15701972
If its crashing or restarting randomly from basic tasks you probably just need to bump its PSU up a wattage notch. With a lot of PC's its better to have a little TOO much watts for a PC by a small margin than have too little and have the system be unpredictable.
I love PC building and gaming.
REMEMBER botttlenecks can happen at all points of a PC part. Make sure you are at equilibrium. For all parts unless you intend to upgrade at a later point. Also QA Tested AAA Games.
https://linustechtips.com/topic/1473941-pc-running-unstable/#findComment-15702748
