Hello,
Just got my computer up and running (new build upgrade from my old 2015 system) and I got a set of the white up here fans 6 pack off Amazon that are rgb.
I have a asus rog b550-f WIFI II motherboard and I plugged the 3 pin plug on the rgb controller labeled “mobo” plugged into the addressable led port (4 pin size but 1 missing) and all I’m getting at the moment is the controller seems to just be cycling through all the different types of light modes it can do.
I am able to control the the led asus logo at the top left of the mobo through the asus software and also through Corsair software for the vengeance ram (which also the ram won’t hold the rgb profile I set)
just looking for any insight on to how to get my mobo, ram and fans all synced up!
thanks 🙂
https://linustechtips.com/topic/1473424-aura-fan-sync-help/
