System Data is Using 171 Gb - MacOS
Solved by maplepants,
"System Data" is a lot of stuff. I have almost twice as much, but I've got every development SDK installed as well as many sounds for Logic and Main Stage for example.
It's better to to use something like DaisyDisk which can give you a directory based breakdown of what's eating your harddrive space. You'll find OneDrive files stored in `~/Library/CloudStorage` and can see there if that's what's eating more space than you expect.
