What model of Noctua 120mm fans should I be using?
Solved by Shooterdude34,
i have their NF-S12a fans, and i love them. theyre rediculously quiet but move a decent amount of air. The nf-a12x25 is the best all around from their lineup but can be somewhat pricey at 30-40$ per fan. the s12-a is more often 15-20$ per fan. the nf-s12 b is also a decent option and can be found for $15.
If youre not putting the fans in a tiny case or on a radiator/fin stack, youre most looking for a airflow optimised design rather than pressure optimised.
