Budget (including currency): 600-900 euros
Country: Netherlands
Games, programs or workloads that it will be used for: gaming, Mostly Call of duty, Dead by Daylight, Runescape.
Hi!
Looking to upgrade my pc but dont know where to begin my first thought was upgrading the cpu motherboard and cpu cooler. Im experiencing that my pc cant run multiple things at the same time anymore, well it can but not that fluent anymore. Im not the biggest pc build pro so my knowledge isnt the best.
just looking for advice and help with terms etc. Looked into the intel 13th gen the i5 but just dont know what i should he looking for.
I’m planning om upgrading my GPU next year so wouldn’t mind overkilling on one end know and even it out later on.
thanks in advance and will awnser any questions that will come up 🙂
Current parts:
MSI RTX 2080 x gaming trio 8gb
intel i7 7700k
Gigabyte z270 ultra gaming
Corsair vengeance pro 2x8gb 3200mhz
Samsung M2 1tb ssd
240hz 1080p monitor
144hz 1080p monitor
https://linustechtips.com/topic/1472587-need-advice-to-upgrade-pc/
Most def the CPU first, 2080 is still decent for now, either 13600K but a bit over budget (or go with DDR4 to be cheaper) or 7700X.
I'd say DDR5 is the way to go since there's a chance that your next upgrade could still reuse the DDR5 RAMs. My personal choice is 13600KF, because it is a gaming beast.
https://nl.pcpartpicker.com/list/LTg9Ls
CPU: Intel Core i5-13600KF 3.5 GHz 14-Core Processor  (€352.95 @ Azerty)
CPU Cooler: Deepcool AK620 68.99 CFM CPU Cooler  (€81.85 @ Alternate)
Motherboard: MSI PRO Z690-A WIFI ATX LGA1700 Motherboard  (€288.00 @ Amazon Netherlands)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  (€195.85 @ Alternate)
Total: €918.65
https://nl.pcpartpicker.com/list/8mPR6r
CPU: AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor  (€388.35 @ Amazon Netherlands)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (€228.95 @ Amazon Netherlands)
Total: €895.00
Or reuse the RAM and go with 5800X3D.
https://nl.pcpartpicker.com/list/DpkYBj
CPU: AMD Ryzen 7 5800X3D 3.4 GHz 8-Core Processor  (€399.00 @ Paradigit)
Motherboard: ASRock B550M Steel Legend Micro ATX AM4 Motherboard  (€133.85 @ Megekko)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (Purchased For €0.00)
Total: €614.70
Occassionaly visits the forum when I have nothing to do at work.
Thanks! This is something i can work with.
couple of questions come up. In thinking to go with the first. So to swap to DDR5 would you advice to also step over to Windows 11 with because of the 13th gen or stick to windows 10?
if i could squeeze my budget should i then go for the i7 13700k? And if so would the rest stay the same?
currently have a 700W power supply should this still be enough for both considering builds?
thanks again 🙂
Total: €918.65
Total: €895.00
Total: €614.70
thanks again 🙂
Honestly, win 11 is not as bad as people say it is, and it has better scheduler for e-cores, so yes, go with win 11.
13700k is way more power hungry than 13600k, at this point I'd say a good AIO is needed, my personal recommendation is Arctic Liquid Freezer II 240 or 360.
700W PSU should still be enough, 13700k peak power draw is around 250W, while gaming maybe less than 200W, 2080 peak is 215W, so yes it is enough.
Thanks! Will look into the AIO’s
If some more questions come up could i ask them maybe trough discord? If you dont mind obviously :)!
I'm sorry but I'd rather not, I only surf LTT forum at work to kill time, so I'd rather not be bothered outside of work time.
Anyway, this forum would be much more helpful than me, just post another thread with specific questions.
Agreed. win 11 is not so bad. been using it for a year now and I do feel like I like win 11 better, but I still hate the new settings/control panel. but its mostly a set it once and leave it thing so its fine. installing powertoy and explorer patcher helps make it more customizable.
RELOAD BEFOR QUOTING. I EDIT MY POST ALOT!
MARK MY POST AS THE ANSWER IF I HELPED.
CPU: AMD Ryzen 5 5600 | GPU: RTX 2070 Super | Mobo: MSI X470 Gaming Pro | RAM: Corsair vengeance 32GB 8x2 3200mhz CL16 | SSD: Samsung QVO 870 1TB | PSU: SeaSonic FOCUS Plus 750 Gold 750 W 80+ Gold | Cooler: Thermaltake Contac Silent
12 | OS: Windows 11 Pro | Pcpartpicker: https://pcpartpicker.com/list/rGR6gb
Displays: ViewSonic XG2401 23.6" 1920 x 1080 144 Hz
Laptop: Lenovo Ideapad Gaming i5-1130 RTX3050 16GB | OS: Windows 11 Pro
