I'm looking for a new wireless keyboard  my old Microsoft one has died. It does not have to be mechanical all it needs to be is wireless because I use my very small desk for Homework and I is often moved out the way to create space.
Thanks
A few I'm looking at.
http://www.amazon.co.uk/Logitech-K360-Wireless-Keyboard-Black/dp/B0055JDM06/ref=sr_1_14?ie=UTF8&qid=1399048371&sr=8-14&keywords=wireless+keyboard
http://www.amazon.co.uk/Logitech-920-003745-K270-Wireless-Keyboard/dp/B0074486GA/ref=sr_1_3?ie=UTF8&qid=1399048714&sr=8-3&keywords=wireless+keyboard
My System now I5 4670k ,H100i, Z87X-D3H, 8GB of Black Muramba, 7970 Sapphire with backplate , Thermaltake chaser A31 black with blue accents ,AX 760 With Blue Cabels, Samsung 840 120gb SSD ,1TB Black ,256 Ultra Plus SanDisk
https://linustechtips.com/topic/147189-wireless-keybord/
imo you should go to a store and try the keyboard. i ordered a keyboard online and i cant type on it to this day. shoulda tried it first.
if you are reading this you are wasting valuable time and should maybe rethink your life choices.
https://linustechtips.com/topic/147189-wireless-keybord/#findComment-1966015
