Replacement for mp600 pro xt
Solved by Weezy,
34 minutes ago, Emerik1098 said:That's what I was thinking too at the beginning but if I want to upgrade later and install the ssd in a pcie gen4 slot I would have to remove the whole front plate permanently and I don't really wanna do that. Basically, short term it works but long term it doesn't.
I guess in that case, I would recommend the Samsung 980 Pro. It's been on sale for $170-$180 for 2TB. It comes in a version with a heatsink and one without. That's my other Gen 4 SSD, and also blazing fast, top reviews, etc etc
