Budget (USD): $900-$1200
Country: USA
Games, programs or workloads that it will be used for: Gaming/Streaming: LoL, Overwatch, Ark, PUBG
Other details: My friend has been gaming from a laptop for years and is having me look into building him a new desktop.  Without considering peripherals, his budget is around $1000, give or take.  It will be mostly hidden in a desk shelf, so no RGB are needed other than maybe the front fans.  His current laptop features a GTX 1660 Ti and runs most games on medium settings.  I am aiming to allow him to push Ultra/Epic settings on most games while on duo 1080p monitors (it's possible he pushes for 1440p).  Here is his list of requirements:
  • Includes WiFi 6
  • Only one large SSD storage (he caused a mess of his SSD/HDD combo)
  • Run his games at high graphics
  • New parts except GPU
I have created two builds that should be nearly identical as an option for Intel/AMD CPU. 5600X Build or 12400F Build. I know I am overspending on the storage, but it seems like the best way to make it as fast and user friendly as possible for him.  I am using the RTX 3060 as a placeholder, I will be looking on r/hardwareswap to find a good GPU around the $250 range.  I am only familiar with Nvidia cards, so I was thinking a 2060 Super or better would be the target.  I've got about a month to put it together so I can be patient for a good deal.  Do you guys have any thoughts, critiques, or advice for me?
Edit: I'm going to paste the build below for readability
~ PC ~
Motherboard : Asus TUF GAMING B550M-PLUS WIFI II Micro ATX AM4 Motherboard  or MSI MAG B660M MORTAR WIFI DDR4 Micro ATX LGA1700 Motherboard
CPU : AMD RYZEN 5 5600X or Intel Core i5-12400F 2.5 GHz 6-Core Processor
RAM : Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory
Storage : Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive
GPU :
PSU : Corsair CX650M (2021) 650 W 80+ Bronze Certified Semi-modular ATX Power Supply
Cooling : Cooler Master Hyper 212 Black Edition 42 CFM CPU Cooler & 4 case fans
Case: DIYPC Vanguard RGB ATX Mid Tower Case
Edited by LockdownJimmy
Updated storage to match recommendation
Gaming PC Build
AMD Ryzen 5 5600X CPU, Cooler Master Hyper 212 RGB Black CPU Cooler, Gigabyte B550M Aorus Pro-P Micro ATX Motherboard, Corsair Vengeance RGB Pro 16GB (2x8GB) DDR4-3200 CL16 Memory, Western Digital Black SN770 1TB NVMe SSD, EVGA FTW2 GAMING GTX 1070Ti Graphics Card, Corsair iCue 4000X RGB ATX Mid Tower Case, Corsair CX600M 600W Power Supply, Asus PCE-AC68 Wifi Card, Acer Nitro Pbmiipx 24" 1080p 165 Hz Monitor, BenQ GL2460 24" 1080p 60 Hz Monitor, Corsair Strafe Keyboard, Logitech G502 Lightspeed Wireless Mouse, Beyerdynamic DT 770 Pro 80 Ohm Headphones, Logitech C920 HD Webcam, HyperX DuoCast RGB USB Microphone,  LTT Store Nothern Lights 47"x31" Desk Pad, Secretlab TITAN Evo 2022 Chair
https://linustechtips.com/topic/1470894-1000-pc-build-advice/
Does the range have to be $250? If your friend is willing to go more towards the 1200$ price range, a 450$ GPU is attainable
Honestly, the 980 pro is not worth it. Just get a 970 Evo plus for like 40$ cheaper
Don't sleep on sleeper PCs
https://linustechtips.com/topic/1470894-1000-pc-build-advice/#findComment-15679391
I'd look into AMD cards - they're often well below MSRP, even new. I'd also probably spend more of the budget on the GPU - it's the most important part of a gaming pc, after all! I got an RX 6700 XT for my build in a similar price range.
https://linustechtips.com/topic/1470894-1000-pc-build-advice/#findComment-15679398
If he's comfortable moving closer to $1200 that is definitely an option.  I also don't want to have him overspend if he won't see any performance difference over the next couple of years.
Good catch!  I'll make that change.
Gaming PC Build
https://linustechtips.com/topic/1470894-1000-pc-build-advice/#findComment-15679408
Look for 6600 XT or 6700 XTs. They are around 400$ themselves. These are comparable to a 2070 super and 3060 ti, respectively.
https://linustechtips.com/topic/1470894-1000-pc-build-advice/#findComment-15679421
You're right, I will probably convince him to expand the budget a bit for a better GPU.  Should I just trust the benchmark on the AMD cards and treat them as equivalent to a Nvidia of the same performance, or is there anything else I should consider with them?
Also, the tower cooler would be a way to save a few bucks. From what I've read, the 5600 and 5600x run plenty cool with the stock cooler.
I've seen the same.  My 5600X runs on a Hyper 212 and I haven't seen it top 70 degrees.  I'm just hesitant to run a stock cooler.
Gaming PC Build
https://linustechtips.com/topic/1470894-1000-pc-build-advice/#findComment-15679423
AMD cards have worse raytracing and encoding, at least this gen. If those don't matter to him, then they're often better price to performance. I bought my 6700 XT for $340, but this can vary by area. As far as the tower cooler, I'm no expert, but people say that you lose another 5 degrees with the stock cooler. Not absolutely crazy, but definitely worse than the tower cooler. At this point, it probably depends on whether you want to spend more on the gpu "half" of the system or the cpu "half".
https://linustechtips.com/topic/1470894-1000-pc-build-advice/#findComment-15679471
Yall realize this is totally doable without bending over backwards, right?
Check this, meets all the requirements for $1000:
PCPartPicker Part List
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($139.00 @ B&H)
CPU Cooler: Thermalright Assassin X Refined SE ARGB 66.17 CFM CPU Cooler  ($22.90 @ Amazon)
Motherboard: ASRock X570 Steel Legend ATX AM4 Motherboard  ($133.99 @ Newegg)
Memory: OLOy MD4U1636181CHKDA 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory  ($71.99 @ Newegg)
Storage: Kingston NV2 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($129.99 @ Amazon)
Video Card: ASRock Radeon RX6700XT CLD 12G Radeon RX 6700 XT 12 GB Video Card  ($339.99 @ Newegg)
Case: Zalman S2 ATX Mid Tower Case  ($54.99 @ Amazon)
Power Supply: Thermaltake Toughpower GF1 PE 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($79.99 @ Newegg)
Wireless Network Adapter: Intel AX200 802.11a/b/g/n/ac/ax M.2 Wi-Fi Adapter  ($24.99 @ Amazon)
Total: $997.83
Generated by PCPartPicker 2022-11-29 18:57 EST-0500
  • The 5600 is exactly the same as the 5600x but it's cheaper
  • The motherboard is a bit excessive but it's on a really good sale, and it has an m.2 wifi port so you can use that ax200 wifi 6 / BT combo chip and it'll work just like integrated, and not take up any space
  • You can do 32GB of memory easily with this budget, and it only costs a little more than 16GB
  • 2TB of gen 4 space is easy, the NV2 is still the best buy
  • You can get an 850w fully modular 80+ gold tier-A PSU for the price of that tier-b 650w in your list.  You don't need 850w, but it's better than any of the 650w or 750w unitss in its price range and there's really nothing cheaper worth getting
  • The Hyper 212 is overpriced with new models that exceed or match it's cooling for less.
  • Good airflow case with fans included.
If he really wants that case, go for it but its airflow is not good compared to cheaper alternatives that include fans.
If you really want one with a glass front and RGB fans, any of these are a better deal:
You can also get a better 6700xt if you go to eBay:
I edit the shit out of my posts.  Refresh before you respond.
https://linustechtips.com/topic/1470894-1000-pc-build-advice/#findComment-15679840
