Budget (including currency): 2000
Country: usa
Games, programs or workloads that it will be used for: gta apex warzone
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): 144hz 1080p
just would like to know if this is good for my buget https://pcpartpicker.com/list/
https://linustechtips.com/topic/1470677-first-build/
29 minutes ago, bread123 said:
That's an empty link, there's no components.
Great selection tho, if you don't need a computer ^^
Trans Rights!
Please tag me or use the "reply" function so I get a notification
I will find your Laptop thread and I will recommend an ITX build instead
Sure would be neat if there was something useful here, eh?
https://linustechtips.com/topic/1470677-first-build/#findComment-15677784
