Today I was applying some GC-EXTREME compound to my i7 2600 (non K). I already knew that only a blob the size of a rice grain was enough, but it was so little that couldn't seem to be able to spread it around with the included applicator. I added another blob and spreaded it which covered the whole surface area of the integrated heat spreader. It looked like it was a fine layer so I closed the case and fired it back up again. To my surprise, I opened up Core Temp to find that temperatures had risen a few degrees. Also when running a torture test on Prime95 (in-place large FFTs), temps got up to 96c. Before I applied the paste it got up to around 82c.
I would have thought it would have reduced the CPU temps by at least 5 degrees celsius?
So obviously I have applied to much thermal compound. Could someone show me what is a suitable amount?
CPU: i7 2600 @ 4.2GHz  COOLING: NZXT Kraken X31 RAM: 4x2GB Corsair XMS3 @ 1600MHz MOBO: Gigabyte Z68-UD3-XP GPU: XFX R9 280X Double Dissipation SSD #1: 120GB OCZ Vertex 2  SSD #2: 240GB Corsair Force 3 HDD #1: 1TB Seagate Barracuda 7200RPM PSU: Silverstone Strider Plus 600W CASE: NZXT H230
CPU: Intel Core 2 Quad Q9550 @ 2.83GHz COOLING: Cooler Master Eclipse RAM: 4x1GB Corsair XMS2 @ 800MHz MOBO: XFX nForce 780i 3-Way SLi GPU: 2x ASUS GTX 560 DirectCU in SLi HDD #1: 1TB Seagate Barracuda 7200RPM PSU: TBA CASE: Antec 300
https://linustechtips.com/topic/147016-too-much-thermal-compund/
No need to spread the thermal paste..
Just one grain and press heatsink on
watch a linus build guide
Are you new? Please read CoC  Before posting! PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR US DARK THEME USERS (Only for dark shades)If you can read this, it means you need to change to NIGHT THEME (bottom left above LMG logo) Please follow your threads and Quote people when replying to them. Mark your problem as solved if answered. Don't spam, nobody likes a spammer. DO NOT QUOTE IMAGES! BE NICE!
https://linustechtips.com/topic/147016-too-much-thermal-compund/#findComment-1963300
Thanks for that, I feel like such an idiot. I've seen the same thermal paste being spread before, so I thought that was what the applicator was for. Thanks!
Also, I don't have any isopropyl alcohol, can I still clean it off with a tissue?
https://linustechtips.com/topic/147016-too-much-thermal-compund/#findComment-1963326
