Program will close due to security problem.
Could you help me with this one please. Every time I try to run this one game, after more less 1min I'm having the message "program will close due to security problem. error 0x70000,0xB0" and that's it. No explanation what the problem is or nothing. I tried to google the error but all I got is error while Mac disc replacement and something linux. I've updated Nvidia drivers, dl latest Visual C++ Redistributable from MS, moved game from HDD to SSD and M.2, validated game files, multiple times, uninstalled and deleted game folder from my disk. Nothing works.
What is that? I never come across something like that.
I'm running the latest updated W10
https://linustechtips.com/topic/1469897-program-will-close-due-to-security-problem/
0x7000 is a device driver error
the 0xB0 means that UTF-8 can't decode it
Go here for a possible solution,
https://appuals.com/fix-error-0xc00007b-application-was-unable-to-start-correctly/
It could simply mean that you have a 32-Bit driver on a 64 Bit system.
1 minute ago, binks said:
Game - Dysterra, system spec - should I make DXDiag report? What spec are important here?
I’d throw together your system in pcpartpicker.com and throw the link in here. This gives exact models of each part of pc and overall is generally accepted.
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
Ryzen7 3800x
32Mb DDR4 Ram
GTX 1080Ti
Forgot to mention, already did those apart CHKDSK and using this Restoro Repair(what even is that?)
18 minutes ago, binks said:
Ryzen7 3800x
32Mb DDR4 Ram
GTX 1080Ti
yeah just the basics, psu, motherboard,  hard drives still missing there.
and windows is up to date? can you see something in device manager about missing drivers?
-Scott Manley, 2021
Yeap, sorry about that, forgot.
Psu-Corsair850x
AsrockX470Taichi
M.2-W, SSD-Samsung, Hdd-Sygate
Everything in device manager is up to date, W10 is updated daily
On 11/25/2022 at 9:52 PM, binks said:
Any ideas? I'm out of them😑
any mods, any overclocks?
otherwise reinstall the game
DDU and reinstall gpu drivers
make sure bios and chipset drivers are up to date
if none of that helps consider reinstalling Windows
the problem is there isn't a lot of info about this error, we also don't know what you've already tried etc (the above are really the basics to check/do) and since this seems to be a system error most likely something seems wrong with your windows install, hence reinstalling should be considered.
-Scott Manley, 2021
eh, uh... did you read this?
they're suggesting to "google it" a dll...
i would definitely suggest *not* to do this ... i think at that point just reinstalling windows would be a better, more safe option?
-Scott Manley, 2021
