Country: Netherlands
Games, programs or workloads that it will be used for: Cyberpunk, Witcher 3 (new gen upgrade) Hogwarts 1440P
Hi all,
I posted a while back for some input on my GPU.
The build is now almost complete. I'm already running with the new GPU and PSU. Now its time to upgrade RAM and CPU i've build this on PC-partpicker.
PCPartPicker Part List: https://pcpartpicker.com/list/Mkj8v3
CPU: AMD Ryzen 7 5800X 3.8 GHz 8-Core Processor  ($234.08 @ Amazon)
CPU Cooler: be quiet! Dark Rock 4 CPU Cooler  ($79.59 @ Newegg Sellers)
Motherboard: MSI X470 GAMING PLUS MAX ATX AM4 Motherboard
Memory: Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory  ($97.99 @ Newegg)
Storage: ADATA XPG SX8200 Pro 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($74.98 @ Amazon)
Video Card: Asus TUF-RX6800XT-O16G-GAMING Radeon RX 6800 XT 16 GB Video Card  ($653.79 @ Amazon)
Case: Thermaltake View 32  TG ATX Mid Tower Case
Power Supply: Cooler Master MWE GOLD 750 V2 FULL MODULAR 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($119.99 @ Newegg)
Operating System: Microsoft Windows 11 Pro Retail - USB 64-bit  ($199.99 @ Amazon)
Case Fan: Thermaltake Riing 48.79 CFM 120 mm Fans 3-Pack
Monitor: MSI Optix MAG271C 27.0" 1920 x 1080 144 Hz Curved Monitor
Monitor: Samsung Odyssey G5 C34G55T 34.0" 3440 x 1440 165 Hz Curved Monitor  ($399.99 @ Abt)
Total: $1860.40
Generated by PCPartPicker 2022-11-22 15:21 EST-0500
So the only things i don't already have is the CPU (currently Ryzen 5 3600)  and RAM (currently Crucial 16GB 3200mhz).
What do you think? Any suggestions? 🙂
https://linustechtips.com/topic/1469349-upgrade-build-almost-done/
I don't have a good eye for upgrades that cut close in power, I know who has. @RONOTHAN##@ShawtyT30beTHICCC
Anyways, only CPU and RAM?
Well talking about RAM there is not much to gain in games,
is your old RAM really slow? how fast is it?
current PC:
PC configs I used before:
Hi all,
Total: $1860.40
Your ram is fine. The 5800x is a waste though. Just update bios and slot in a Ryzen 5600 or 5700x
CPU-AMD Ryzen 7 7800X3D GPU- Gigabyte WindForce SFF RTX 5070ti MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE- 2TB Samsung 990 Pro PCIE4 NVME x2 PSU-Corsair RM1000x Shift COOLING-Lian Li GA II Lite 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-Samsung G61 QD-OLED 1440p 240hz +Gigabyte G24F 1080p 180hz PERIPHERALSVaxee XE-S+Padsmith Crucible Mousepad+Monsgeek M1 V5 TMR+Autonomous ErgoChair+ AUDIO-Audient iD4 Mk II + Rode NTH100
Hi, thanks for the input,
How would the CPU be a waste?
fyi the 5800x is in sale here right now for like 200 euro's thats why i picked it.
Thanks anyway 🙂
Thanks anyway 🙂
well if it's cheaper or same price than what @ShawtyT30beTHICCC suggests, it's no longer a waste
current PC:
Just now, Kjellergy said:
Thanks for the reply,
Old ram was a bit budget ram 16 GB 2400mhz
oh yeah, from 2k to 3k speeds you will see a difference
current PC:
Yeah that's what i figured haha.
And 32 GB is nice to have i guess.
No problems with the wattage of balance of the PC. Bit worried i'm bottlenecking something in here.
don't worry about that, there is always bottle neck,
as for the wattage, you're already running CPU with the new GPU on a new PSU,
new CPU is only 40W TDP more in cooling, which isn't much, pcpartpicker calculates 550W and you have 750W PSU, you're fine
current PC:
i also suggest you check out megekko.nl
it usually has lower prices then pcpartpicker says, and isnt always displayed if you say your region is the netherlands/belgium.
i saw they had a 6900XT for 650€ today (i believe it was the asrock phantom gaming OC model or something like that)
so thats a lot more performance for a little more money
btw the rest of your rig looks good!
I almost always buy from megekko, i got my 6800xt a few weeks ago so i wont upgrade it yet 😛
But thanks for the heads up!
Everything should be fine then.
Thanks!
