Budget (including currency):1200 - 1400
Country: germany
Games, programs or workloads that it will be used for:  Mostly 1080p gaming (CSGO, Valorant, DOOM, Call of Duty, Battlefield, Horizon Zero Dawn, etc.)
Other details: As of now i have this parts in my list https://pcpartpicker.com/list/9gjsgb
I want to play games at 1080p on my 144hz monitor. Also i might try some Games with RT, thats why i have selected the RTX 3060.
If you would change something let me know 🙂
Thanks for any tips
https://linustechtips.com/topic/1468371-first-pc-build-any-suggestions/
Cut the cooler, get cheaper mobo, get cheaper SSD such as Kingston NV2, and lower the PSU to 650w. Reallocate the budget to a better GPU, maybe 3060 Ti, my recommendation is 6700 XT.
5600x don't need after market cooler, there are better value motherboards, that SSD os overpriced, and you dont need 750w PSU for 3060 ti or 6700 xt.
Also, RT with 3060 is barely enjoyable, you need a strong GPU for RT, basically don't hope for 60+ fps with RT on, maybe with DLSS set to performance.
Occassionaly visits the forum when I have nothing to do at work.
Welcome to the forum!
PCPartPicker Part List: https://de.pcpartpicker.com/list/7rRy78
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  (€163.00 @ Mindfactory)
CPU Cooler: Cooler Master Hyper 212 EVO V2 62 CFM CPU Cooler  (€39.99 @ Amazon Deutschland)
Motherboard: Asus TUF GAMING B550M-PLUS Micro ATX AM4 Motherboard  (€134.90 @ Alza)
Memory: TEAMGROUP T-Force Delta RGB 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (€45.99 @ Alternate)
Storage: Western Digital Blue SN570 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (€73.98 @ Amazon Deutschland)
Video Card: Palit Dual GeForce RTX 3060 Ti LHR 8 GB Video Card  (€459.00 @ Computeruniverse)
Case: Corsair 4000D Airflow ATX Mid Tower Case  (€112.35 @ Computeruniverse)
Power Supply: Enermax Revolution D.F. 650 W 80+ Gold Certified Fully Modular ATX Power Supply  (€79.90 @ Amazon Deutschland)
Case Fan: ARCTIC P12 PST A-RGB 0dB 48.8 CFM 120 mm Fan  (€12.90 @ Alza)
Case Fan: ARCTIC P12 PST A-RGB 0dB 48.8 CFM 120 mm Fans 3-Pack  (€36.90 @ Alza)
Total: €1158.91
Generated by PCPartPicker 2022-11-18 17:39 CET+0100
Notes: much better build and cheaper
7 hours ago, QBateman said:
Thank you! I will look up some other GPU's
I have chosen the after market cooler because i heard that the 5600x Box cooler gets loud
It is, but for a first build, it is the best place to save a buck and get better hardware at other place.
It could always be an upgrade later, like 2 to 3 months from now.
