15 minutes ago, ChaosComputerZ said:
Hey I have a Ryzen 5 4600G cpu
im on a super tight budget with like 113$ left is there any any low profile gpus that are compatible with my cpu and good enough for entry gaming
Dumpster dive on craigslist. May get lucky with like a 1070 or something
CPU-AMD Ryzen 7 7800X3D GPU- Gigabyte WindForce SFF RTX 5070ti MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE- 2TB Samsung 990 Pro PCIE4 NVME x2 PSU-Corsair RM1000x Shift COOLING-Lian Li GA II Lite 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-Samsung G61 QD-OLED 1440p 240hz +Gigabyte G24F 1080p 180hz PERIPHERALSVaxee XE-S+Padsmith Crucible Mousepad+Monsgeek M1 V5 TMR+Autonomous ErgoChair+ AUDIO-Audient iD4 Mk II + Rode NTH100
https://linustechtips.com/topic/1468249-help-me-find-a-gpu/#findComment-15660470
RX580 8gb or 1060 6gb, great 1080p cards.
for 150 you can get 1070 or 1080 if you're lucky.
https://linustechtips.com/topic/1468249-help-me-find-a-gpu/#findComment-15660488
