Hello!
I recently bought a HDD enclosure for an old 60GB HDD I had laying around. I got it because my dad wanted a hdd to put his music in and since the enclosure only cost €7.5 it was cheaper than a 2.5" external drive. The problem is that I knew he had around 50GB of music but I didn't know the exact amount. The formatted HDD has 55GB available and my dad's music collection is 59GB in size... Do you have any idea how I could put it in there, I tried NTFS compression but Windows won't let me copy it. If I used 7zip I could probably get it under 55GB, but I'm not sure if foobar2000 can use compressed folders as media sources.
What do you think? Thanks!
i'm a potato
https://linustechtips.com/topic/146806-i-need-ideas/
try compressing the audio files? better yet, delete songs/albums/artist's he doesn't want.
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
https://linustechtips.com/topic/146806-i-need-ideas/#findComment-1960456
store some of them online
in the clouds
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/146806-i-need-ideas/#findComment-1960457
Yeah, he needs to look trough it and delete some stuff.
in the clouds
I uploaded it all to Google Play Music but he doesn't like the interface. It's a shame though.
You could compress the music to 256Kbps or 128Kbps or only some of the music.
Most of it is 192Kbps already, is the difference between that and 128Kbps big? And is the sound difference big?
i'm a potato
https://linustechtips.com/topic/146806-i-need-ideas/#findComment-1960484
So destroy the quality of the music just so it'll fit, makes sense...
Mein Führer... I CAN WALK !!
https://linustechtips.com/topic/146806-i-need-ideas/#findComment-1960491
I would recommend this option more than compressing  :lol:
https://linustechtips.com/topic/146806-i-need-ideas/#findComment-1960500
I have compressed my music from 320Kbps to 192Kbps. I can not tell the difference.
I can tell on quite a few songs of mine that were 192Kbps vs 320Kbps doing blind test controlled by someone else but anything after 320Kbps I can't and likely nobody can tell the diffenace.
https://linustechtips.com/topic/146806-i-need-ideas/#findComment-1960554
Please do not start a discussion on audio files, etc. There are other places to do that (youtube comments on teksindicate's audio myths)
I'm probably going to convert the files, my dad isn't much of an audiophile, he cares about the song, not about the quality of the sound, and a lot of the music he has are rips from mp3 CDs.
EDIT: Do you suggest any programs?
i'm a potato
https://linustechtips.com/topic/146806-i-need-ideas/#findComment-1960585
mmmm, nope. I said "better yet, remove unwanted songs/music. before compressing" lol.
https://linustechtips.com/topic/146806-i-need-ideas/#findComment-1960607
I would suggest LAME encoder and FooBar2000.
Quote me to get a reply!
https://linustechtips.com/topic/146806-i-need-ideas/#findComment-1961038
