Wi-Fi and Bluetooth Adaptor On The Same USB Hub?
Muhlis
If I plug a USB hub to my computer, then connect a Wi-Fi and Bluetooth adaptors (separately) on the USB hub, would it be a problem?
No, as long as there is enough power provided to the peripherals, everything will work.
A powered USB hub would make sure everything has enough power and you don't damage anything (like the port it's attached too) by overloading it.
I agree with @Naijin. It should be fine with enough power. Most peripherals/USB devices work together on the same hub.
