Recommended Fan Curves For My PC
Solved by Dukesilver27-,
The case is the problem, no matter the fan curve or how fast the fans spin, they will always be loud because there's almost no airflow.
That case is a notorious hot box, your components are all high powered, here's your choices:
either ditch the case and get a new one,
or remove the panels of the case so those fans could pull air,
or undervolt and limit power usage which might only help a little,
or stay with your current setup but run them at high temps.
