Budget (including currency): 2,500 USD/
Country: Building In Japan
Games, programs or workloads that it will be used for: Will probably use it for a combination of Gaming, being able to run Elden Ring with most settings at high. I would also like to be able to use and render video editing programs without struggling through waiting 30 minutes to render but as long as it can run decently well I would be happy.
Other details : I'm building from scratch as a first major gaming PC, I'm planning on one monitor but plan to later get another one of a similar size or weaker . I have most of the PC part's picked out but I'm unsure if I going way over on parts that I don't need or haven't seen better alternatives for similar prices. I have all of the peripherals so where already budgeted for. I'm looking to buy within the next month but would rather it be sooner.
This is the link to the PC parts picker I have created as a rough draft. https://pcpartpicker.com/list/dFNRhk
Thank you for helping.
https://linustechtips.com/topic/1467284-help-building-pc-from-scratch/
5 minutes ago, Ryuikko said:
To clarify you're buying in the us? Are you stuck on that case? There's nothing wrong with it, but 200 dollars is a pretty decent amount for a case
Not really married to it just want to get something and I'm unsure how much I should put into case. I'm in Japan for the foreseeable future so my purchases would probably happen in Japan besides Amazon, but I haven't been here for too long so my cash is still mostly in USD, so I just put USD as the rough idea, not sure if that kind of clouds it though.
Very roughly what id reccommend since jp pcpartpicker has little to no gpus and 0 psus listed with prices
PCPartPicker Part List
CPU: Intel Core i5-13600KF 3.5 GHz 14-Core Processor (¥51966.00 @ Newegg Japan)
CPU Cooler: Cooler Master MasterAir MA612 Stealth ARGB 62 CFM CPU Cooler (¥18416.00 @ Newegg Japan)
Motherboard: ASRock Z690 Extreme WiFi 6E ATX LGA1700 Motherboard (¥33025.00 @ Newegg Japan)
Memory: TEAMGROUP T-Force Vulcan Z 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory (¥16457.00 @ Newegg Japan)
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (¥33528.00 @ Newegg Japan)
Video Card: Asus TUF GAMING OC V2 GeForce RTX 3070 LHR 8 GB Video Card (¥98909.00 @ Newegg Japan)
Case: Fractal Design Focus 2 RGB ATX Mid Tower Case (¥24550.00 @ Newegg Japan)
Power Supply: Corsair RM850x (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply
Total: ¥276851.00
Generated by PCPartPicker 2022-11-13 14:28 JST+0900
Total: ¥276851.00
Oh shit, thanks a lot for the help.
