Fan Layout
Go to solution Solved by thrasher_565,
36 minutes ago, NextraMia said:
I'm going to switch from my current case to the o11 dynamic since I got it on a sale.
My planned fan configuration is to have my AIO on the side as intake, 3 fans on the bottom as intake, 3 fans on top as exhaust and the last fan in the back as exhaust.
Is there a better way to have it configured? Also, is it good to have the 3 intake fans pulling air into the graphics card where the GPU exhaust fans are located or should I go to the length with vertically mounting my GPU?
Suggestions are appreciated 😄
nop horizontal is best. is certain situations it can work. fan layout is also good.
CPU: AMD Ryzen 9 5950X ||| GPU: Gigabyte GeForce RTX 3090 GAMING OC ||| Motherboard: Asus Rog Crosshair VIII Dark Hero ||RAM: G.Skill Trident Z DDR-4400 CL16 ||| PSU: Corsair HX Platinum 1200 W 80+ ||| Case: Lian Li - O11 Dynamic Evo ||| Storage: 2x Samsung 980 Pro 2 TB NVME SSD ||| Cooling: (CPU: EKWB RGB 360 AIO) (Case-Fans: Lian Li SL-120 Infinity)
https://linustechtips.com/topic/1467282-fan-layout/
Edited by thrasher_565
https://linustechtips.com/topic/1467282-fan-layout/#findComment-15653119
okay, thanks! 😄
https://linustechtips.com/topic/1467282-fan-layout/#findComment-15653139
