RX 580 heat going up to 97
Solved by UnusualDevices,
1. Are gpu fans spinning? according to that screen 0 rpm but that may not be correct.
2. update bios/ddu/reinstall drivers
3. if that doesn't work you may need to repaste your gpu.
Featured Topics
atxcyclist ·
Posted in Home Theater Equipment0 -
3
ElChales ·
Posted in New Builds and Planning4 -
Gundmi ·
Posted in Troubleshooting0 -
ElChales ·
naldo29 ·
Posted in Troubleshooting2
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
