Issue with port forwarding
Go to solution Solved by Biohazard777,
Are you running software on that port?
You can't check port status if there is no service currently using / serving on that port.
Hi, I want to forward a port to my (Windows 10) PC. Here is what I did:
-Gave my PC a static internal IP address
-Reserved this address for the PC in my router's menu
-Forwarded the port to this address in my router's menu
But when I go to canyouseeme.org and enter the port I forwarded, it says "Error: I could no see your service on (public ip) on port (the port I forwarded). Reason: Connection timed out."
Any idea why this is happening? Am I doing something wrong? Could it have something to do with me using my Raspberry Pi as a DNS server?
Thanks in advance.
https://linustechtips.com/topic/1466835-issue-with-port-forwarding/
27 minutes ago, TheGreatestGazoo said:
Check the firewall on the PC - it may not be allowing the port through it.
Thanks for the advice. I made a rule in Windows Firewall to allow that port through the firewall, but I still get the same error on canyouseeme.
I don't have anything using that port, no. It's just testing for a future project. Is that why I am getting the error?
