Toggle between PC and MAC
Solved by brob,
You will likely need to use a DP to HDMI cable.
Search for "kvm 2 port dual dp usb 3.0 audio". Several options.
kasdashd ·
1
6
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
