First PC Planning
Solved by Ryuikko,
38 minutes ago, Thomaskippa said:I am trying to keep the white, especially with the white an black H7 theme. I think it looks sick. And thank you for the help.
I'm assuming the black comes from the psu? If so then it looks like a good list! Only minor complaint would be the ram, 3200 cl16 is usually cheaper, so I'd have a look at that instead
The h7 flow dosent look as bad as its h510 variant, I think it'll be fine as well.
