Budget (including currency): £300
Country: UK
Games, programs or workloads that it will be used for:
unity,
 a very large variety of games tbh
  • CPU
    Ryzen 5 2600
  • Motherboard
    Asrock b450m Steel legend
  • RAM
    16gb corsair DDR4 3200
  • GPU
    AMD RX 5600XT Thicc ii pro
  • Case
    Fractal design Meshify s2
  • Storage
    2tb Samsung ssd
    500gb Samsung ssd
    500gb crucial ssd
  • PSU
    Corsair RM650
    Hello,
    i have a budget of £300 pounds and wanting to upgrade my pc, im not quite sure what i should upgrade first my cpu/mobo or just cpu. Or my gpu, any suggestions within the £300 budget or should i save more and get something a bit more at a later date?
https://linustechtips.com/topic/1464832-help-upgrading/
While your budget equates to 344 USD, that's not necessarily a linear comparison on which to go by.
That said, though I prefer Invidia GPUs, what you've got really isn't bad at all, and I'm not sure a processor upgrade would really be worth it, as the 2600 is a pretty hot little number for a Zen+. You might consider a GPU upgrade, but I'm not sure your budget permits anything worth doing.
THAT said, I believe your board should have a PCIe M.2 slot, and a PCIe M.2 could greatly decrease load times over what appear to be existing SATA SSDs. However, most AMD graphics cards are more than somewhat reliant on PCIe4 speeds to run well, and this could create issues with your GPU, so I would research this first.
Otherwise, I would suggest perhaps waiting a bit longer to save up for a 3060 / 3060ti, they seem to be the sweet spot in terms of price / performance for Invidia's lineup.
Edited by An0maly_76
Revised
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
https://linustechtips.com/topic/1464832-help-upgrading/#findComment-15634173
Otherwise, I would suggest perhaps waiting a bit long to save up for a 3060 / 3060ti, they seem to be the sweet spot in terms of price / performance for Invidia's lineup.
Thanks, ill definitely look into a m.2, but ill probably end up saving for a 3060ti, again thanks for the advice
https://linustechtips.com/topic/1464832-help-upgrading/#findComment-15634191
NP. Be aware that M.2s come in PCIe and SATA versions, and though some B+M slots can accept both, they do not interchange from a speed standpoint, a SATA M.2 isn't really faster than a SATA SSD. They are keyed differently -- B or M key.  Here is a list of the different PCI keys and what they support. The last 2-3 digits of the type (2280, 22110, etc.) are the length. As you can see, M-key goes for the gusto. But as I said, PCIe4 M.2 could cause issues with your GPU, so be sure of this before doing so. The drive may throttle back to PCIe3, but it may force the GPU to throttle back to PCIe3 also, hurting performance.
Revised, more info
https://linustechtips.com/topic/1464832-help-upgrading/#findComment-15634201
