Where can I store computer parts if I don't have their original packaging?
Solved by Dukesilver27-,
Basically any box would do, just make sure no form of moisture could get to it.
People have placed their PC parts everywhere, a lot of tech hoarders just put the parts on a shelf in a well ventilated room.
Try looking at some of tech hoarders videos on youtube, their parts still work even if they just store them on a wooden shelf.
Jays Two Cents have their GPUs on wall mounted displays, Linus also store his CPUs on a CPU plastic bin, only protected by a CPU casing to protect the pins.
And yes, you need to reapply thermal paste if it has been in contact with air for quite some time, it will dry out.
