Are extension cables something that people usually buy? I just purchased a full CableMod cable kit and also noticed that they sell extensions, but I'm not sure if they are needed. I would think that the cables that come in the kit should be long enough for most cases and routing options. I really want good cable management and don't want to run into issues with something not being long enough.
https://linustechtips.com/topic/1463987-do-i-need-extension-cables/
The cables that you got should be plenty long enough.
Extensions are a cheaper way of having "pretty cables."
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
