Game drops frames from 60 to 30 for a split second every few seconds on external display, but not on the main laptop display
Solved by Nana6541,
3 hours ago, Eigenvektor said:Do you have V-Sync enabled? If enabled the GPU will synchronize to the monitor's refresh. If it misses an update window, it'll have to wait for the next one, dropping to half that i.e. 60 to 30.
2 hours ago, Hairless Monkey Boy said:You didn't answer the question. Do you have V-Sync enabled?
I may have found the solution.
Just updated my Intel iGPU driver and restarted as was required, I booted up Fortnite in Fullscreen mode with the same settings and it worked just fine.
It could easily break again if I restart, so I hope it won't!
