First time building pc
Go to solution Solved by fAED,
If you want to stay inside your budget you'll have to lower to a 6800 XT which is also a great option!
The price on PCPartPicker isn't actually acurate:
  • You don't need a water cooler on a Ryzen 5600.
  • The DeepCool GAMMAXX GTE V2 which is a good option for your 5600 is listed at 39.40€ but there is actually a deal at reduxgaming.nl for 25€.
  • I managed to get a AK400 at megekko.nl for 39€. Right now is out of stock, but that one is also a very good option for your build!
  • Cooler Master V750 V2 750 W 80+ Gold is at 75€ at megekko.nl
  • I changed Motherboard & SSD so you save 35€.
  • That RAM is 2 expensive, and I changed it for cheapest 3600Mhz CL16 (non-RGB)
- Added 3 fans because that case only comes with 1 fan I guess.
-  Tried to stay within the white looks.
9 hours ago, Ailema said:
The monitor I choose is from Germany, I checked prices there. I still don't know if they ship to The Netherlands, but yeah, that's the cheapest I could find. The other day I actually saw the MSI OPTIX G273QF at 299€ at 'alza.de', maybe that is also a good option. Thankyou
I don't know which website is good for that in Germany, I just can tell you that amazon.de delivers to NL alot of items. But if you can, MSI G273QF it's a better option.
  • Keep in mind that RDNA3 almost 1 week away, and black friday in 1 month.
  • Perhaps you won't be able to purchase a good RDNA3 for the same price of a 6800 XT in the short run, maybe between 6-12 months if you can wait 😃
PCPartPicker Part List: https://nl.pcpartpicker.com/list/28ywpH
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  (€172.95 @ Azerty)
CPU Cooler: Deepcool GAMMAXX GTE V2 64.5 CFM CPU Cooler  (€25.00)
Motherboard: Asus TUF GAMING B550-PLUS ATX AM4 Motherboard  (€138.85 @ Megekko)
Memory: Kingston FURY Renegade 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  (€79.90 @ Amazon Netherlands)
Storage: Crucial P2 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (€80.90 @ Amazon Netherlands)
Video Card: Asus TUF-RX6800XT-O16G-GAMING Radeon RX 6800 XT 16 GB Video Card  (€669.00 @ Azerty)
Case: Corsair 4000D Airflow ATX Mid Tower Case  (Purchased For €105.00)
Power Supply: Cooler Master V750 V2 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (€75.00)
Case Fan: Cooler Master SickleFlow 120 ARGB 3 In 1 62 CFM 120 mm Fans 3-Pack  (€39.99 @ Amazon Netherlands)
Monitor: HP X27q 27.0" 2560 x 1440 165 Hz Monitor  (€270.00)
Total: €1656.59
Generated by PCPartPicker 2022-10-23 19:11 CEST+0200
Budget (including currency): 1700€
Country: The Netherlands
Games, programs or workloads that it will be used for: Gaming (COD, Overwatch 2)
Other details: I need to add a new monitor, maybe 1440p, IPS, 144Hz - (I'm trying to make a white build also)
- Maybe I can strech it to a 5700X or maybe a 12600K, but I really don't know how I can make it to budget level...
PCPartPicker Part List: https://nl.pcpartpicker.com/list/btL6Ls
CPU Cooler: Cooler Master MasterLiquid ML240L V2 RGB 62 CFM Liquid CPU Cooler  (€78.84 @ Amazon Netherlands)
Motherboard: Asus ROG STRIX B550-A GAMING ATX AM4 Motherboard  (€153.85 @ Megekko)
Memory: Mushkin Redline Lumina 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  (€90.00)
Storage: Samsung 980 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (€94.90 @ Amazon Netherlands)
Video Card: Asus TUF GAMING OC Radeon RX 6900 XT 16 GB Video Card  (€819.00 @ Azerty)
Power Supply: EVGA 850 GQ 850 W 80+ Gold Certified Semi-modular ATX Power Supply  (€83.90 @ Megekko)
Total: €1868.44
Generated by PCPartPicker 2022-10-23 18:43 CEST+0200
Thankyou 🙂
https://linustechtips.com/topic/1462806-first-time-building-pc/
Total: €1656.59
https://linustechtips.com/topic/1462806-first-time-building-pc/#findComment-15619557
