Budget (including currency): $2000 willing to go over budget a little if necessary
Country: United States
Games, programs or workloads that it will be used for: 3d work, programming, and games: rpgs and fps
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): https://pcpartpicker.com/list/fyydfv
I also have a few questions regarding the components. First, is the cooler fine or should I go with something like the noctua nh-u12s? Second, does the power supply have enough wattage. Lastly, do I need to buy windows os?
https://linustechtips.com/topic/1462293-first-pc-build/
13600k or 7700x
6900xt
Profit?
CPU-AMD Ryzen 7 7800X3D GPU- Gigabyte WindForce SFF RTX 5070ti MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE- 2TB Samsung 990 Pro PCIE4 NVME x2 PSU-Corsair RM1000x Shift COOLING-Lian Li GA II Lite 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-Samsung G61 QD-OLED 1440p 240hz +Gigabyte G24F 1080p 180hz PERIPHERALSVaxee XE-S+Padsmith Crucible Mousepad+Monsgeek M1 V5 TMR+Autonomous ErgoChair+ AUDIO-Audient iD4 Mk II + Rode NTH100
https://linustechtips.com/topic/1462293-first-pc-build/#findComment-15615695
To your "other questions":
-With the mensiond cooler you will be fine for you CPU, but to get a bigger one or maybe an AIO (if you care about looks, it could be better) is rarely a bad thing.
-Powersupply, 650W will nit be enough i guess. But you can calculate something like that easely on sites like that https://www.bequiet.com/en/psucalculator.
-Yea you need to buy windows, but you will be fine buying windows home from a keystore.
I hope i could halp a bit 🙂
https://linustechtips.com/topic/1462293-first-pc-build/#findComment-15615702
If I were to go with an AIO what would you recommend?
https://linustechtips.com/topic/1462293-first-pc-build/#findComment-15616120
I would recommend this instead. Slightly under budget, and much better cpu cooler, case, and psu.
https://pcpartpicker.com/list/XqFk78
CPU: AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor  ($399.00 @ B&H)
CPU Cooler: Noctua NH-D15S chromax.black 82.51 CFM CPU Cooler  ($99.95 @ Amazon)
Motherboard: MSI MAG B650 TOMAHAWK WIFI ATX AM5 Motherboard  ($249.99 @ Newegg)
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  ($209.99 @ Newegg)
Storage: Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($189.99 @ Amazon)
Video Card: MSI GAMING Z TRIO GeForce RTX 3070 LHR 8 GB Video Card  ($544.99 @ Newegg)
Case: Fractal Design Pop Air ATX Mid Tower Case  ($105.98 @ Newegg)
Power Supply: Corsair RM850x (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($149.99 @ Amazon)
$1949.88
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
https://linustechtips.com/topic/1462293-first-pc-build/#findComment-15616142
https://geizhals.de/alphacool-core-ocean-t38-aio-280mm-13053-a2829547.html?hloc=at&hloc=de
or
https://geizhals.de/alphacool-core-ocean-t38-aio-360mm-13052-a2827692.html?hloc=at&hloc=de
both of them are cheap and still doing a greate job cooling you system. If you want to OC i would recommend the 360 version, but normal use u will be fine with the 280 (other point would be looks, bc if you put a 280 in there would be a empty spot o one with an odd normal fan, but thats matter of taste...).
https://linustechtips.com/topic/1462293-first-pc-build/#findComment-15616427
