Bsod's after adding another memory stick
Go to solution Solved by SpookyCitrus,
This is because you are mix matching memory which is a no no. Regardless of if you buy the exact same make and model of ram stick there may still be incompatibilities. If you want more ram you need to buy a dual module kit, the kits are tested and paired from the factory to work together. That's all it is.
Hi! Just added another 16gb of 5200mhz ddr5 to my system but i keep getting bsod's. I have checked to see if they both are picked up by the system and sure enough they are both there and visible on the bios screen.
There are a few messages that i keep regularly seeing and they are:
System_service_exception
Kmode exception not handled
Page fault in nonpaged area
Pfn list corrupted.
All these problems seem to be gone if just use one stick but idk if i want run on single channel.
https://linustechtips.com/topic/1461863-bsods-after-adding-another-memory-stick/
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
